2.5 L Transporter engine mounting bosses
    I was (past tense) under the impression that the I5 2.5L transporter block had all the mounting bosses that would allow it to be "easily" mounted in an S2 or, in my case, a 93 C4 body S4 (where the AAN sits now). Someone has suggested to me that my assumption was wrong and that motor/engine mounts have to be fabbed to make it work rather than just bolting OE mounts to the 2.5 L block.
    Anybody with direct experience with this?
    do a few searches for Marco & jeffer aswell i think, quite a while back they documented alot of work he did on this conversion.
    • john881000
      • May 2004
      • 598
      question
      HI
      ARE YOU REFERING TO THE T25 VW TRANSPORTER ??????
      IN SOUTH AFRICA WE HAD THE T25 VW TRANSPORTER MICRO BUS/CARVELLE
      WITH THE 2.5 LITER 5 CYLINDER AUDI ENGINE (later made to 2.3 and 2.6 liter).....FROM THE UITENHANGE(incorrect spelling) FACTORY IN SOUTH AFRICA
      THIS ONE WAS SAME AS THE BLOCK AS THE C3 AND C4 AUDIS( 100 AND A6 SHAPE AUDI)
      SAME MOUNTING BOLT HOLES ETC
      HOPE THIS IS OF SOME USE
      cheers
      john
      • caterpillar
        • 2480
        the 2,4 AND 2,5 DIESELBLOCK fit in old vw passat 32b too.... bolt on, no prob....and i used the unit from a vw 84 passat..... so you use the unit from the engine who WAS in the bay....
          • stroker
            • Jul 2006
            • 57
            Yup & here in the good ol US of A I'm using a Eurovan 2.5l gas block & 95.5mm crank & it's bolt in to the 90 CQ US model. Board it out to 83mm & vwella 2.6l monster!
            thanx
            Ron
            90 CQ 2.6l 20vt stroker project...sikRs2
            91 v8q 5spd DTM project
            91 200 20v
            93 v8q 4.2 "Der Green Monster"
            90 v8q not stock..Urs8 gone but not forgoten :-(
