boost is fluctuating at full boost/sometimes boost problem
  • Ws2
    • Nov 2006
    • 56
    Only at full boost (1,4-1,5 bar) the boost is quick fluctuating according to the boost gauge between 1,3-1,5bar.
    It seems like the effect is greater when it's cold outside.
    Is this normal?
    The engine is running great, but sometimes boost is reduced to 0.5bar.
    After a restart, the engine is running great again.
    WGFV, DV are renewed, pressure hoses are o.k, no fault codes
    The car is a stock s2 3b with mtm chip (262hp) and open airfilter.
    Any idea what it can be?
    Thanx!
  • YELL MAN
    • Dec 2005
    • 535
    • Country: Shetland Islands
    Try cleaning the MAF maybe? It solved boost issues for me.
    1994 Indigo Blue S2 coupe
    1994 80 Avant 1.9 TDI
    2005 Yamaha Fazer 1000
    1953 AJS Model 18S
    • Ws2
      • Nov 2006
      • 56
      Thanks, i'm going to try it!
      • s2_bo
        • Oct 2005
        • 6067
        Is this normal?
        Thanx!
        I had exactly the same problem - it kept getting worse and worse.
        It would boost to 1.4 -1.5 bar then after a few minutes cut right down to .5 and not go any higher until engine restart.
        I also replaced:
        WGFV
        MFTS
        ARS
        etc etc..
        Turns out it was the knock sensors.
        I replaced them both (one had completely bare cable showing.)
        Now its fine again.
        I would try that if i was you.
        Good Luck.,
        Cheers.
        Bo
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • Ws2
          • Nov 2006
          • 56
          It's not getting worse and worse, it's more from time to time, mostly it happened on the highway driving at normal speed, never under full load.
          But i'm going to check it!
          • terrybullwon
            • Mar 2006
            • 8782
            Lmao, i have the same problem in 5th gear at 22psi the gauge flutters at 100-120mph and you get a stutering induction noise and the aceleration gets a little lumpy.
            BUT the car pulls like nutts all the way through 1,2,3 and 4th untill you come on to 100mph
            Chef
            • terrybullwon
              • Mar 2006
              • 8782
              I have just got my wgfv and i will let you know if this makes any difference
              James
              Chef
              • smogthemog
                • Oct 2006
                • 149
                Does Boots sell IPAlchohol for cleaning MAF's ?
                Jim
                Jim B
                97 S6 AAN Quattro Avant C4 | Powerflow Cat Back EX | Milltek Hyperboost RV | MAC N75 Valve | FMIC | HID's (Dip & Fog's)| MRC Re-map SII | Carbon interior | De-chromed | Short shift | Samco Air Hoses |
                http://smogthemog.blogspot.com/
                  Brake cleaner is mostly IPA
                  • smogthemog
                    • Oct 2006
                    • 149
                    I thought most brake cleaners were Trichloroethane based
                    Jim B
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      not solved with a new wgfv
                      Chef
                      • LHD_Kid
                        • May 2006
                        • 3695
                        Just wondering if any of the above was sorted out...?
                        • Ws2
                          • Nov 2006
                          • 56
                          With the cold weather the boost problem is gone for so far.
                          Thats why i suspect the knock sensors, must check them still, but just cleaned the maf.
                          And the boost is still fluctuating quick at full (over)boost, but don't think it is bad, the car is running fine.
