Oil leak Precision turbo
  • s0_big
    • Dec 2009
    • 685
    Hi! Noticed today that my turbo was smooking a little of the exhaust housing. Removed my turbo blanket and found a small trace of oil coming out between the exhaust housing and bearing housing. The turbo is a Precision 58/58 (not bb). Worked fine with my setup for 2 years so i don't think it has something to do with my oil-drain or oil feed. Any one that have experienced this with their turbo? Is there a gasket between the housings? because i don't find any info about this on the net.
    This gallery has 1 photos.
  • SteveH
    • 4460
    Shaft seals are likely leaking a little. It's rebuild time if it gets worse or you can't live with it as it is.
    91 Modded 3B
    14 A6 Avant Black Edition
    • s0_big
      • Dec 2009
      • 685
      But if it is the shaft seal, wouldn't it smoke from the exhaust then? Not leak there?
      • s0_big
        • Dec 2009
        • 685
        Somebody other than me must had this issue? Or did I just have bad luck..
        • s0_big
          • Dec 2009
          • 685
          Nobody had the same issue?
