Roose motorsport boost hoses for an ABY don't seem to fit.
  • grim
    • Apr 2014
    • 106
    I've spent the day swearing at my car trying to change the boost hoses over to silicone ones since i developed a boost leak from a broken down hose. Waited 5 weeks for these things to turn up and they don't seem to be quite right. Has anyone else fitted these?
    The largest boot from the maf to the turbo seems to be quite a way out and I can't get everything connected up. I've stuck a pic up here, I've tried various orientations and can't get it right. Pop the old boot on and it all fits beautifully.
    This gallery has 1 photos.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    I have just ordered my first set of coolant hoses. I hope they are not THAT bad
    • rxl
      • 1913
      as i remember right you need to cut a few centimeter from the turbo side and then it will fit ... oh and i had to cut the headlight holder few centimeters..
      • grim
        • Apr 2014
        • 106
        I was perhaps naive to think they would fit without fettling. I was on a time constraint as well to get the car back together so I've put the original back on and it's holding boost well, so at least I know it wasn't this one. I'll have a measure up tomorrow because you can at least do this one easily from the top and see if I can get enough room before I start hacking up an expensive hose that might not fit at all.
        • LSG
          • May 2010
          • 897
          I have the same hoses on my ABY don't remember having to much trouble fitting them. I'd be very surprised if they have changed anything but they are hand made. Before you cut them around can i suggest calling the company. I have water hoses and boost hoses very happy with them and will get more water hoses from them. You also have to remember that they are a lot thicker walled that the standard hoses so you will have to fight them on. Are all the holes on the hoses the right size. If they are then it should fit. Hope you get to the bottom of it best regards Lynn.
          • jade
            • Jan 2005
            • 1811
            i am have problems with one of there water hose the one that goes from block to heater seems to be wrong diameter on block end
            RS 2 580HP
            • Henkjan
              • 1705
              I remember it was also a difficult fit, and had to modify it somewhat to make it fit on my ABY
              • grim
                • Apr 2014
                • 106
                Everything fits into the holes just about, but that breather to the cam cover just can't be connected up. I didn't have too much trouble getting any of them on really. It was super hot and sunny so I left the hoses on the drivers seat of the car and selected them as I needed them, they were nice and warm and soft from the hot car.
                Also the logo logo is upside down on the hose that goes to the solid pipe to the throttle body. So if I do get this maf boot connected up, the two logos side by side will be different to each other. Nicely planned out...
                I'll give then a ring tomorrow and see what they suggest.
                Thanks for the replies.
                • Tridac
                  • Mar 2012
                  • 88
                  Haven't replaced the hoses on mine yet, but was thinking of using plastic drain pipe or heating copper pipe for long runs of the boost hose, as it would be more robust. Then use short rubber sections just at the ends. Use the standard plastic pipe cement to glue together after loosly fitting and marking. Don't know how well it would work, but plastic should handle the temperature fine...
                  • Colesy
                    • Feb 2009
                    • 2980
                    Would turning the hose on the turbo anticlockwise help?
                    • grim
                      • Apr 2014
                      • 106
                      I spoke to a helpful chap at Roose today, he was confused by my problem and said it's a very popular kit that he's never had a complaint on before. He's requested lots of photo's of both hoses from all angles to try and figure out what's up but I think it looks like I might be able to get the clearance I need by chopping it down a bit.
                      I don't believe I gained anything from rotating the hose on the turbo either direction. I spent about 10 minutes farting around with it trying to get that breather pipe connected up but it's not having it as it is.
                      • AndyP
                        • 6049
                        Have they sent you a 3B hose instead of ABY?
                        • s2driveruk
                          • 12696
                          i have to say I was thinking the same...
                          1992 3b S2 Coupe
                          • Living the dream
                            • Jan 2017
                            • 19
                            I got a 3B hose kit for 1991 S2 with the 3B engine and had to modify the metal breather pipe that comes in to the side of the hose between MAF to turbo inlet pipe. Roose motorsport boost hoses don't fit ABY or 3B engines
                            • s2driveruk
                              • 12696
                              We had similar issues with the original batches of the Samcos too if i remember...likely to do with age and condition of the donor hoses. Have to expect some diy but shouldnt be a nightmare...
                              1992 3b S2 Coupe
