Is there a gasket between the wastegate and exhaust manifold or any sort of paste to put on when refitting.
S2 Coupe wastegate gasket
As rlx says there is no gasket there, which is strange since there's gasket every where else. So I found aftermarket gasket that are made to fit, guess I'm not the only one who thought it was strange. I believe you can find the gasket on eBay
Normally there's no gasket, I've never known it to leak there.Comment
