RS2 timing marks
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    RS2 timing marks
    Number 1 or number 2 is the correct?
    Sent from my SM-N9200 using Tapatalk
  • blux
    • Feb 2017
    • 237
    • Country: Belgium
    The groove in the cog needs to be in the middle of the V on the valve cover
    1967 fiat 500 future project
    1976 audi 100 coupe S
    1989 vw corrado 16V
    1989 audi 90 quattro 20V sport
    1994 audi RS2 project
    1994 audi RS2 parts car
    1995 audi RS2 project
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Not in an ADU engine. It's meant to be half a tooth out.
      My car is on the 1st picture and it wont start unless throttle is given. Then stalls.
      Just to mention I run vems therefore I don't have moronic fault codes. I do get primary trigger setting error message though.
      • rxl
        • 1913
        if you set the timing to the right it will be running like crap and if you dont hit accelarator it will idle for a few seconds and the engine goes off.. so the right setting would be half toof out to the left.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          Rxl it does exactly that, by mistake we thought it was to the right rather than the left
          • Torsen20v
            • Jun 2011
            • 9
            • Country: Spain
            Hello,
            Any of both do not have a correct timming. You have in any case a half tooth advance or delay on camshaft so the hall sensor reads wrong.
            These are the most probably cause of this problem.
            1- your camshaft pulley belongs to a S2 ABY o S4 AAN //
            2- your camshaft pulley it is correct but when water pump was changed a 29 tooth WP pulley (mostly of 5 Cyl) was used instead of 26 th ( RS2 ADU)
            I can see in your picture, your Pulley PN is finished in B so is the one for the ADU. Check you Water Pump and count the number of tooth.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              My car is an ADU. Pulley is ADU and water pump pulley is ADU, camshafts ADU as well.
              My question was about the half tooth out which I always remembered wrong, as in ADU engine it never falls on the mark.
              We have put it like picture 2 and it works perfectly.
              So at least we have an image for the forum as I couldn't find one.
              • jade
                • Jan 2005
                • 1811
                Yes just to confirm to the left is correct
                RS 2 580HP
                • rxl
                  • 1913
                  We have put it like picture 1 and it works perfectly.
                  you ment in the picture nr 2 ? to the left. so it works now?
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    Yes picture 2 . All good now
                    Sent from my SM-P550 using Tapatalk
                      For the record
                      • rxl
                        • 1913
                        hehe sucks when you have not right timing on rs2.. you think that its ****ed..
