Unknown connector on ADU engine
  • Unknown connector on ADU engine
    I recently bought an Audi RS2 with original ADU engine.
    At first sight, the car runs normally.
    However, I found a strange connector next to the inlet manifold, which is not connected anywhere.
    Can anyone tell me where this connector should lead to?
    Is it harmful that it is not connected? What are the consequences?
    Thanks in advance for your answers!
    This gallery has 3 photos.
    Based on the location and the lack of connector connected to the brake fluid reservoir level sensor on the side of the tank, I think you have your answer = brake fluid level sensor connector.
      Looks like the fluid level sensor is damaged. Replacement reservoir needed and then full system bleed with good brake fluid.
      Pembo
      quattro - Original 4WD rallying
      Rally Car photos
        Brake level connector color matches my rs2. Also had one with a broken reservoir connector.
        1967 fiat 500 future project
        1976 audi 100 coupe S
        1989 vw corrado 16V
        1989 audi 90 quattro 20V sport
        1994 audi RS2 project
        1994 audi RS2 parts car
        1995 audi RS2 project
          Thanks a lot for your swift replies!
          Should indeed be the connector to the brake fluid reservoir. Quite stupid that I didn't see that myself.
          Since I changed my brake hoses, I was anyhow planning to change the brake fluid. I only fear some issues when bleeding the ABS pump. Can I replace the brake fluid reservoir without having to bleed the ABS pump?
            Reservoir change doesn't need to much fluid bleeding, as it is the top part of the system. Just make sure you don't spill it on your paintwork. If you don't live to far away i can help you out if you want. I live near aarschot.
            1989 vw corrado 16V
              If it is the same tank as in the Ur-S6 -> the level sensor is a separate piece -> no tank replacement necessary...
                Parts catalogue seems to give this as seperate part indeed. 893611377A
                1989 vw corrado 16V
                  Just pull it straight out...
                    Thanks a lot for your responses!
                    I easily removed the sensor by sliding it out. Apparently, the sensor doesn't "touch" the fluid inside the reservoir, I assume it works with a magnetical floater inside the reservoir.
                    Anyhow: the reservoir doesn't leak when you slide out the sensor.
                    Ordered the sensor (part number 893611377A) from Audi (costs 13 euro, excl VAT).
                      Great result and learn something new everyday. Might change mine now!
                      Pembo
                      Rally Car photos
                        Problem solved with new sensor. Thanks a lot for your advice!
                          Thanks for sharing the solution.
                            Agree. I liked it so much I put it all together into an info post on my home forum so the UrS boys could see the problem and the solution.
                            http://forums.quattroworld.com/s4s6/msgs/346810.phtml
                            Dave F
                            • #15
                              Is yours RS2 LHD ? Must be if it is in Belgium
                              Mine is LHD, and with ADU, but brakes can be different
                              Probably I have used as donor car from UK when converted to vacuum brakes
                              as this sensor on my car is on other side then yours.
