Crank pulley bolts
  • bernsaudi
    • Feb 2007
    • 592
    Crank pulley bolts
    Anyone know the part numbers for the 2 tyoes of bolt? Cheers!
    This gallery has 1 photos.
    Ive added part numbers on my project thread a while back S2Coupe 12 years on
    I didnt manage to get a replacement grit coated washer though
    • bernsaudi
      • Feb 2007
      • 592
      Thanks for the reply Greg, are the 4 pulley bolts only audi also?
      • bernsaudi
        • Feb 2007
        • 592
        Re the washers reusable then or should they be changed?
        • Thuppu
          • 4115
          Bulk 12.9 bolts work well here.
            The four allen bolts are available from Audi, but I boight some bolts the right size on line.
            As for the washer if it hasn't been replaced for a while, I couldn't source one before for TPS or Audi Tradition so I didnt have much choice but to reuse the existing washer. I changed it when I rebuilt the engine last so wasn't too worried. Im not 100% if they are supposed to be replaced on each change though
            • Monkeymagic
              • Mar 2012
              • 3419
              http://www.ebay.co.uk/itm/Crank-Shaf...-/371799591500
              • Monkeymagic
                • Mar 2012
                • 3419
                I think I used this bolt. I know I used a febi one.
                • hunker7
                  • Mar 2014
                  • 3487
                  Quattro corner
                  '93 Audi UrS4 Avant
                  '15 Audi A7 quattro 3.0 TDI
                  • bernsaudi
                    • Feb 2007
                    • 592
                    All parts are now sourced I need a locking pin now
                    • AndyP
                      • 6049
                      This one won't fit the petrol engines, the TDi one is longer.
                      • SteveH
                        • 4460
                        Why does the ABY have the washer and the earlier cars don't use it? The cranks are the same and I can't see there being much difference in the front pulley.
                        91 Modded 3B
                        14 A6 Avant Black Edition
                        • bernsaudi
                          • Feb 2007
                          • 592
                          Is this washer the same? ...
                          074 105 193
                          • GazzaG60
                            • 4133
                            it sits the pulley out a bit. makes belt run true. its really a spacer. it was A 25 QUID spacer like 10 yrs ago.
                            if you do like i did first time and use it as a washer on the crank bolt the pulley will run the belt into the casing.
                            was 25 quid i needn't have spent back in the day
                            • bernsaudi
                              • Feb 2007
                              • 592
                              I found a washer in the middle hole of the original timing gear, I take it then that is not the washer we are talking about?
