Oil warning light coming on
  • audi660
    • Jan 2005
    • 162
    • Country: South Africa
    Every few km I drive, the oil light comes on but the car has oil. It's a 1997 S6.
    I hope it's not the oil pump. Can anyone tell me where the oil pressure switch is located, it might be a faulty switch
    [SIGPIC]1997 Ur-S6 SMS Revo S
  • steve briance
    • Aug 2014
    • 1455
    is this since you blocked up the turbo oil return line?
    • LSG
      • May 2010
      • 897
      Only a observation of your post ref oil restriction to turbo. If anyone gives you advice on this problem, will you ignore this to.
      • simons2
        • Mar 2010
        • 344
        You should listen to the experts mate
        • Henkjan
          • 1705
          do you have an oil pressure gauge?
          • NoWay
            • Sep 2009
            • 162
            • Country: Bulgaria
            Hi, I have a AAN S4 and have the same problem. Oil pressure gauge show normal values. The engine is running smooth and quite, but the oil warning on board computer randomly appears. I suspect oil warning light sensor, but haven't have the time to replace it.
              You might want read these:
              20VT Oil Pressure Sender, Switches, Wiring and Check Valves (with UPDATES):
              Oil Pump, Temperature Sender, Pressure Relief Valve Info.:
              • NoWay
                • Sep 2009
                • 162
                • Country: Bulgaria
                Thanks Urs4boy!
                In my case I was planning to change F22, because warning appears at idle also. F1 should be taken into consideration above 2000 rpm.
                • Thuppu
                  • 4115
                  Could also be something wrong with the cluster "board computer" itself(bad solder etc.).
                  • NoWay
                    • Sep 2009
                    • 162
                    • Country: Bulgaria
                    Yes, if the warning still appears after F22 is changed I will check the wiring and the board computer cluster.
