oil pump
  • oil pump
    There is a rebuild kit for it ?
    Yes send it to Jp Jnl racing he will recon the full pump
      Really? He must be a magician now too.
      You can skim the housing to remove axial clearance, you can't do anything about radial clearance without having new gears machined or you can try micropolishing and a DLC coating, both of which costs about the same as a new pump anyway!
        Is the ael pump the same pump or someone used with no issues?
          Last time I looked at 2.5 diesel block I’m sure pump was identical to 3b oil pump? Could be wrong and Jp does recon the oil pump if it’s serviceable condition he told me with out sending it to him he can’t tell all best michael
            My pump needs new gears .. .Options are a new pump or new gears if I find any .I remember seeing at one time someone selling upgraded gears.
              What's wrong with your gears? Generally the housing wears out first.
                I think in Finland I got my diamond coated gear £110 including postage few years back.
                  IIRC it was Repo who had some made.
                  I can do some gears wire eroded and DLC coated but to be honest the appetite for quality and the associated cost has waned on this forum in recent years and it’s not worth the hassle when Febi will supply you with a mediocre new pump for less money.
                    I been looking for one but I didn't find aby only 3b...
                      Main reason for aftermarket oil pump gear is to avoid pump failure. In some cases the outer gear has cracked in pieces. Aftermarket gear is made of better material that doesn't crack so easily.
                        Just bought probably the last pump in Uk from Audi dealership for a good price ! Thanks everyone for info.
                          Are u used a diesel pump or a petrol one?
                          Audi Coupe Quattro 2.3 20V
                            I had the original oil pump and bought a new one .Old one had backlash on years and a bit of wearing on central casing.I didn't had any problems with oil pressure everything is in great condition inside the block.I don't want to take any risks on my new rebuild engine that's all.
                            • #15
                              Ok, but u didnt wrote which pump u have? 3B ? The new one..
