Garrett GTX3582 Gen2
  • #16
    momento1
    i have a first Log with the Gen2.
    408kw @ wheel
    • #17
      Originally posted by Prosac
      momento1
      Prosac i cant see the link??
      Current:
      1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
      Past:
      2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
      2001 Audi S3 Silver - 169kw+ atw
      • #18
        its with Aral 102 + Toluol.
        408kw @ wheel
        • #19
          Is this just running in? or are you starting to work on full tune?
          How did you find spool up/response?
          and also power?
          Current:
          Past:
          • #20
            im very interested in this to. mine is waiting to go on.. though mine has bone stock head
            • #21
              3rd gear full throttle.
              The response is really good. I would not have expected this.
              The HX40 took a little longer. Also tonally Is the GTX another world.
              408kw @ wheel
              • #22
                any dyno nr? what are your engine spec?
                • #23
                  No. I Wasnt at the dyno. The Screenshot Is only a Test at the Road. Without changing the Software.
                  408kw @ wheel
                  • #24
                    not bad.
                    Pretty good response. Similar to what i was achieving. Approx 32psi at 4600rpm i achieved before the wastegate started to open and slowed the boost climb up to 36psi
                    What exhaust manifold you running and what size downpipe?
                    any flow work done to the head?
                    Current:
                    Past:
                    • #25
                      Hi. I have a TiRon Tubular Manifold and a 89mm Downpipe with oem wastegate.
                      408kw @ wheel
                      • #26
                        This gallery has 4 photos.
                        408kw @ wheel
                        • #27
                          Very nice Prosac
                          Stock size valves also?
                          Current:
                          Past:
                          • #28
                            Yes. Stock Valves.
                            408kw @ wheel
