Had a half hour today to help a mate with his S2 estate....it doesn't start.
Engine turns over but no feed to fuel pump, the relay has been replaced and still the same. Prior to the non start situation, when last run the rev counter was sticking at 2000rpm and half the dash lights weren't working, I doubt this is related but thought I'd mention it?
Checked for battery voltage at pin 30 of fuel pump relay.......ok.....so bridged pins 30 and 87 but still no feed at pump. Fuse 13 intact but no voltage here when cranking. Gave pump a direct feed, pump runs and draws 6 amps......so cranked engine but still it doesn't fire up.
There's battery voltage at injectors, wasn't able to check for switching when cranking.
The battery has been charged and engine turns over fast enough.
Before I trawl through wiring diagrams and posts on this here good forum.....anyone any thoughts.
One spanner in the works is that it has a Sigma immobiliser, the control unit for it is behind the dash as seen when we replaced the heater matrix. I haven't checked for coil switching/HT spark and as mentioned injector switching.
Thanks in advance.
John.
Thanks in advance.
John.
