Looking for a possible air leak S2 ABY Coupe
    S2 parts for sale, garage clear out.
      Second post
      • orsum
        • May 2010
        • 1213
        • Home: United Kingdom Current: South Africa
        Going to a local supplier of silicon hoses they uses 4 ply. Will see what they have.
        I also noted a difference in shape of the hose that goes to the BPV when using a Roose silicon hose.
        Can anybody offer an explanation why Audi designers would make such an loop on the original instead of the simple looking route the Roose silicon hose takes.
        I am thinking it is because of the engine flexing and the BPV being static, the loop just takes the movement up while keeping the BPV static??? I see the loop also goes through a steel support ring also think it could be to reduce the movement on the BPV.
        • Rusty
          • 18953
          Don't forget to block the breather off or you'll pressurise the crank case and end up with lots of blue smoke on startup as well as a leak on the oil cap
          No idea why the BPV was dome like that other than for servicing, as it can easily be pulled out.
          Get the Roose kit, it's a quality product.
          • orsum
            • May 2010
            • 1213
            #20
            Leak fixed.
            Still deciding what to replace the original pipe with.
            While deciding what pipe to buy original or silicon I had a 316 SS thin walled T pipe made, cut the rubber T pipe out and fitted my metal home made T piece. Pressure holding leak fixed. No test drive yet giving the underside a good HP clean and fitting the 996 front calipers first.
              Nearly there now
              • orsum
                • May 2010
                • 1213
                #22
