Just renewed my cam sensor was a bit apprehensive but it was easy , took upper X member out of the way ,belt cover off ,cable ties belt to cam pulley , marked crank and cam pulley with tipex cracked cam bolt off eased pulley off ,removed 2 screws that hold cam sensor bkt and its off , replacement was a reverse of dismantling URS4boy Dave supplied the information in one of his quattro blogs Thanks Dave
