Audi s2 3b coupe 1992 K26 turbo Wagner evo rs2 manifold
  • skikar
    • May 2017
    • 7
    • Country: Norway
    Hi guys
    Audi s2 3b coupe quattro 1992
    Have any of you have this problem after installing
    K26 turbo
    Wasgate stock
    Pictures with stock downpipe
    Pictures with 3inch downpipe
    Wasgate flens is not in line se pictures
    Any solution
    Thanks
    Sent fra min BLA-L29 via Tapatalk
  • SteveH
    • 4460
    You'll need to modify your downpipe wastegate pipe.
    91 Modded 3B
    14 A6 Avant Black Edition
      Put the wastegate in the vice, make sure the flexi is the right way round, put a piece of tube down the flexi pipe and bend it over a bit.
      Sorted.
      • mac2226
        • Jun 2008
        • 1289
        Or if you can fabricate or know some one who can remove wastegate flexi put it in a vice chop each side flexi remove flanges and bolt them back on each side of dp/wastegate side buy a 2” stainless flexi and some 2” pipe chop them to right length tack them into position make sure there’s few tacks otherwise it will fall apart remove and weld on bench tig/mig all best michael
          It really only needs to be bent a little, no need to overthink it.
