rs2 flywheel options
  • Eastcoastrs2
    • Sep 2013
    • 95
    • Country: Australia
    I am replacing my clutch at the moment and when my mechanic pulled the car apart he found that the flywheel also needs replacing. Dual mass so can’t resurface. Can anyone point me in the direction of a new one or good second hand one? I have an option from Germany 2nd hand good condition with 150,000km on stock setup. It’s 150 euros but the postage to me is 200 euros!
    whats people’s thoughts on single mass options like the 7a with a spacer? and again can anyone point me in the direction of where to buy that option?
    cheers
  • rxl
    • 1913
    are you sure you cant resurface it? there are companies that refubish used ones.
      You can fit a single mass and lose the spacer but you’ll hear the gearbox jingling in the flywheel under load at low RPMs
      • Eastcoastrs2
        • Sep 2013
        • 95
        I didn’t think you could resurface dual mass?The mechanic said something about it being eaten out. At load my revs would go up but no power then I just couldn’t change gears on day. I thought the clutch was slipping hence the change but when he opened it the clutch still had some meat left it’s the flywheel that has been slipping.
        • rxl
          • 1913
          there are companies that rebuild dual flywheel. maby its better option to get it resurfaced. if not i have a used clutch kit cheap
            What’s the state of tune of your car and what’s your driving style?
            • valukonis
              • Feb 2016
              • 26
              • Country: Lithuania
              In Lithuania it is no problem to rebuild dual mass flywheel, somethink about 200eu
