Ski's engine problem
  • AbsS2
    • 285
    Ski, Dunno if this will Help, but i had exactly the same sort of problem... Would be on and off over a period of three weeks. In the end it blew my 5th cylinder spark plug right out..
    The car would rock.. really crappy acceleration.. it would rev slowly, felt as if the clutch was slipping.. gear stick would shake like hell.
    So I would say check the cooil lead is on properly and check the seating of the spark plugs too!
    PS when it did blow the spark plug, i had oil all over y the block.. and a nice james bond style blue mist from the back effect
    Coupe
    • Ski
      • 2591
      that helps a LOT!!! many thanx... its been recommended to me to check this item.
      Due to long working hours, i have booked wednesday to fix this problem, so i will check the plugs, coils, leads, compression test etc..
      hopfulle, i will have same problem as you, and it will be a simple coil / plug replacement.. lets hope its as simple as it sounds and hope i dont encounter the james bond stylie effect
      any other sugestions welcome...
      ABY Coupe
      • Ski
        • 2591
        Hi fellas...
        had a look at my car today..
        did compression test etc.. all ok..
        HOWEVER.. my 4 month old (according to the dealer) spark plugs are like charcole black and were "loosley screwed in".
        im gonna get a new set of plugs..
        coils looks new.. all looks ok..
        im hoping, praying and this will solve my problem.. what u think abss2?
        ABY Coupe
        • AbsS2
          • 285
          I think it will be due to spark plugs being loose or bad coil lead to one of the spark plugs. Basically car is misfiring thats why the crappy acceleration, rocking and bad idle.
          PS im not mechanically minded, but thats what was causing my problem.
          Coupe
          • porkkis
            • 1994
            I just noticed this thread but it really sounded as a ignition problem from the first post.
            Hope the new plugs will solve this. I could nearly bet they will.
            To you all: Check regularily that your plugs are tight. The 20v head tends to loosen them by itself!!!!!
            • Ski
              • 2591
              #21
              im gonna change the plugs today and see what happens..
              The coils look new... cant see any plugs looking "odd" compared to others.. but they all black like ****....
              ABY Coupe
              • porkkis
                • 1994
                They should be a bit black. That's normal. The electrode should be clean.
                • Stick Insect
                  • Dec 2003
                  • 2338
                  Originally posted by Ski
                  i get a small smell of cats coming from the rear with this problem.
                  I'm not saying a word...
                  Hope you cure the problem Ski.
                  GSF or Eurocar parts will be cheaper for the plugs.
                  David
                  • Ski
                    • 2591
                    #24
                    fellas...
                    i put new plugs in.. it cost me like £60.. and no difference what so ever.. still mis firing like hell...
                    the engine dude recons its the coil on cilender no.2.
                    as you know each coil is like mega money, and he says no way to test it.
                    is there a way to test a sprak plug coil?
                    ABY Coupe
                    • Ski
                      • 2591
                      #25
                      looks like its the coil.. it can only be...
                      any way to remove a coil form its... big metal plate buddie?.. seems wires are... soldered to it.. buggar...
                      ABY Coupe
                      • porkkis
                        • 1994
                        Hmm test 'em then. Take the fuel pump relay out, fabricate somekind of grounding for the plugs and leave the ignition assy on the engine having the plugs grounded (with something you just made) to the engine properly. Then ask a friend to "start" the car when you're inspecting the plugs. You should see the sparks clearly.
                        Starting to be a bit tired but hope you understood what I ment.
                        • Ski
                          • 2591
                          #27
                          yes i do many thanx....
                          ive found out its the coil no.2.
                          Any way of removing just the one coil? it seems they are all joined together :S
                          ABY Coupe
                          • AbsS2
                            • 285
                            #28
                            Ski, Yes you can remove just one coil.. just i dont know how
                            Coupe
                            • Ski
                              • 2591
                              #29
                              well i got 2 options... (well 3, but i dont want to buy a whole unit for a million squid)
                              1 ) rip coil out then re-solder the cables to new one
                              2) take it all to million bits, then feed the new cables under the rest of the coils and wire it up to the... main external cable.
                              either way.. its gonna be fussy..
                              im gonna go for adding new one with new cable WITHOUT soldering which means i gonna have to mess around with the wires/cables as they look almost inpossible to untangle/unattach
                              wish me luck, 3 weeks my car has been off the road now.. hopefully i will get a new coil for weekend (hopefully)
                              cheers fellas.. i just hope it is the coil..
                              ABY Coupe
                              • Ski
                                • 2591
                                #30
                                Nope.. it wasnt the coil..
                                im now looking at a burnt/bent valve
                                ABY Coupe
