Anyone got the complete trigger setup for an Audi S2 tall block (diesel block) running ViPec V88?
Crankshaft trigger wheel got 5(?) air gaps and are located inside the engine (see picture). Crankshaft sensor has got two wires (reluctor) even though I'm not sure it's the correct one.
The distributor works as a camshaft trigger (hall sensor)
May very well be the same options/settings in f.ex Autronic.
I'm asking cause I just mounted the 2.5 engine and can't get any spark. Worked fine with the old 2.2 3B-engine.
Thanks.
Thanks.
