561 fault code... any ideas?
  • GT500
    • Jun 2006
    • 2181
    After encountering my first B7 RS4 for a traffic light GP, which i killed him up to 30 then got a nice miss fire and he left me listening to the little V8 howl.
    vag com says 561 mixture adaption not reached.
    Any ideas? 561 is not on ross tech list...
    any help muchos grasseyarse,
    Rob
    Rob..
    87 UR 20v ABY
    97 S6 Avant
  • rj scotty
    • May 2006
    • 2195
    Got the same on mine (95 ABY) but mine runs fine.
    Ive changed the lambda but still there.
    Corry suggested cleaning/replacing the MAF.
    I'm going to clean mine in IPA over night this week ill let you know how I get on.
    Edit: just been thinking about this, it cant really be anything other than the lambada or the MAF nothing else controls the mixture.
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • GT500
      • Jun 2006
      • 2181
      Just found an old post on Audi-sport.net could be
      Fuel pressure low- unlikely.
      air leak down stream of air mass meter- most likely!!!
      I will do a pressure tomorrow.. and then go find mr RS4 again!!!!
      Rob
      Rob..
      87 UR 20v ABY
      97 S6 Avant
      • rj scotty
        • May 2006
        • 2195
        You could be right there with boost leak.
        After I changed the lambda I went from "not reached" to "Exceeded"
        Not sure what this means ?
        Ill clean my MAF and while its off to a leak test.
        • GT500
          • Jun 2006
          • 2181
          Nobbed off,
          no leak, cleaned maf, still got code and miss fire.
          looks like i need a new maf.
          just the expense i need at the moment!!
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • Crawford_S2
            • 1555
            561 can also mean a missfire! Got it pulled on mine the other day.
            Could be inlet/exhaust leak
            MAF
            Lambda
            Fuel pressure
            Missfire!
            According to the helpful computer at my mates workshop
            Also got 544 Max boost exceeded, but i am guessing that is because of the other one
            Oh and the ever present engine speed one cos it was not running
            Cleaning the MAF as i type, need it on for the trip to inters in the morning
            Ragusa Coupe gone!
            • A80Avant
              • 10873
              • Country: Greece
              i got the same fualt today.It clears out as i erase the fault codes,but mine is intermittent.
              reading from s2central,it could be leak in exhaust before catalysts,MAF,fuel pressure regulation.
              Now all i have got is a bit of roughness in idle but no up and downs,and lots of rich mixture....and i mean A LOT!!! what do you suggest???
              I just changed the maf back to my previous one cause the new one gave me all this as well as a VERY unstable idle.I also checked the 2 samco hoses i have from the maf to the turbo inlet and they seem fine.I took extra care to tighten everything back together...This maf i have now is practically new as well,no more than 6-7months old.
              About the fuel pressure regulation,what should i check??
              • GT500
                • Jun 2006
                • 2181
                I just got rid of this code at last!
                N75 changed for new one, made a huge difference, stopped slightly poor idle, loads more bottom end power.
                Also changed maf to a new one, better again, uses less fuel, goes faster!
                Change the N75 first.
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • A80Avant
                  • 10873
                  • Country: Greece
                  did that.N75 is new
                  im thinking of getting a MAF from audi this time.just read info about chinise mafs and didnt like it...
                  • GT500
                    • Jun 2006
                    • 2181
                    Chinnese MAFs?
                    Got mine from the stealers, £162.00
                    Could have got it cheaper at vag parts, but I couldn't wait.
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • A80Avant
                      • 10873
                      • Country: Greece
                      my last 2 mafs where from vagparts unfortunatelly....
                      • chrisarc
                        • May 2004
                        • 44
                        n75
                        excuse my ignorahce , what part is n75 assuming it is a sensor of sorts?
                        • A80Avant
                          • 10873
                          • Country: Greece
                          it is new
                          • A80Avant
                            • 10873
                            • Country: Greece
                            changed the lambd and still getting the same results
                            it seems that when i remove the MAF plug when on idle,the car seems to run a bit smoother.And when i replace it it goes at it again.So im guessing that i have found the usual suspect....
                            awaiting for the maf replacement....
