Originally posted by ristokru
rs2 cold start trouble
No it’s not, the 3B has the same valve for the carbon can, unless it’s already been deleted.. -
As was suggested earlier check out your ignition. If it’s 3b I have less experience as I have ABY but it may be worth considering converting to aftermarket coils if ignition is the issue.Greg
finaly the maf was involved, ive bought a china copy for test and it run fine with it.... so now i'm sure and i ve found a new real bosh hot wire ,for 300 €
its weird the copy uses an other technology ,not platinium wire , but a litte electronic componement ... but it works fine , even with E85 .... so it seems tu run rich .Comment
