Doesn't matter how many engines he does, he can't tune for **** or he can't be arsed.
Gtx3582 gen2 low on power?
hello just to get an update on this.. i ended up switching all togehter.. did end up with a different ecu all together. we did test the car with the map i posted in there on a different dyno that i have had it on before.. it was as low as 470 hp i ended up selling my vems and bought a ffj, ffj is a danish ecu guro.. we got it up to 530 hp on a trusty dyno.. and after that i changed the injectors from siemens deka 840cc to bosch ev14 920cc that bumped the power up to 565 hp with 0.12 bar less boost.. odd. but allways had it in for the dekas being ******.. stil havent got cams in since the ecu change cost a bit. but car runs freaking great now much better than it has ever ran.. stil cant figuere out wich cams i need though
