what would be the best option to get 450 hp in my audi s2?
Audi s2 450 hp
450 hp at the wheels is my hp target too (ABY) and I've been thinking the following:
RE85
9,5:1 CR pistons
FCP X-beam conrods
GTX 3071 gen2
RS2 Evo exhaust manifold
Stock intake manifold
Wagner IC
Stock cams
Stock head
Big enough injectors (need to consult tuner for exact cc)
3" exhaust
1,8T coilmod with R8 red coils
That's my list. Based on my research this should get you at least near the 450 hp goal (at the wheels). I might have forgotten something but hope that helps
Efr 71632013 Touareg TDI /// #farmenwagen
1990 Cq /// Project: Because RacecarComment
I have the SQ em, reverse inlet Wagner, larger intercooler than Wagner, stock pistons and h beam rods, I use the 3071 gen2 at 2bar and make 400whp with nothing more to give. I have the 0.63ar though to allow for fast spool. If you use the 1.01ar you will get a lot more lag but possibly reach the 450whp. However as you are using a high compression ratio as I do, you will be knock limited unless you use e85 in which case you will probably do more than 450Originally posted by Antsa450 hp at the wheels is my hp target too (ABY) and I've been thinking the following:
RE85
9,5:1 CR pistons
FCP X-beam conrods
GTX 3071 gen2
Wagner IC
Stock cams
Stock head
3" exhaust
I bet Issam, aka @Wizard-of-OD can hook you up or help point you in the right direction.2013 Touareg TDI /// #farmenwagen
