Pedal for E-Throttle conversion?
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    Error404 Or could be from R32. These ones are 75mm too i think. PNs 022133062AG and 022133062AA. Maybe cheaper and more avalaible than RS4s
    Audi Coupe Quattro 2.3 20V
      Sure anything can be made to work
      I would stick to a throttle from a forced induction engine though, it will be designed for the rigors of a boosted application. Not all the N/A throttle bodies will hold boost
      • Tom_
        • Oct 2007
        • 1301
        Good point Alex, but when i look on your throttle body P/N (077133062), there is lot of bodies with the same OEM code for V8 TB...OR you have V8 one?
          I have a few throttles here but they are 079133062G or 077133062 ~ 75mm throttle.
          077133062 is actually quite a rare unit as was only supplied on a few varieties, B5 RS4, some D2 V8, some C5 V8.
          077133062A is the larger 82mm unit which is very easy to find.
          • Tom_
            • Oct 2007
            • 1301
            #20
            Thanks for explanation Alex...077133062 is very easy and cheap to find here and 077133062A too...079133062G is not so easy and not so cheap, but as you said, its from turbo car so maybe the best choice for forced induction engine
              077133062 is used in B5 RS4
              • Tom_
                • Oct 2007
                • 1301
                #22
                So i think that it doesnt matter if its used in turbo engine or N/A engine whilst OEM code is the same for bot applications...
                  In this application, clearly. But you can't assume this the case for all
                  Bottom line, go with a proven solution, or be prepared to solve problems
