Pedal for E-Throttle conversion?
  • Pedal for E-Throttle conversion?
    can see that some people in here have converted to e-Throttle on their i5s.
    im going the same way and are looking for a gas pedal that is bolt-on. Can somebody supply me with a part number?
    running Maxxecu Race.
    thanks in advance
    You can use a pedal from a TDI 80 B4
      http://www.oemepc.com/audi/part_sing.../721055/part_i
      this one?
        You need the complete B4 1Z pedal box, and a gas engine throttle pot. Have a check of my project thread mate, all the info is in there
          Error. Could you plz put a link Up
            https://www.s2forum.com/forum/member...tidy-up/page77
              No info on that page, you should link the post.
              Users can change posts per page settings, so no point in linking to specific page.
              You need diesel B4 pedal box and TPS from gasoline car. Like B5 and etc.
              1989 Audi 80 Quattro
                Is there Any tb that has the s2 Stock pattern. For easy swap on inlet ?
                  Regarding the TPS from d2. Can i use from 4.2 for instans?
                    D2 - different bolt pattern. A solution would be a flange...
                    Team RS
                    Grundey Intake
                      For a custom setup I use TPS and pedal from 3.2FSI/2.7biT
                      Team RS
                      Grundey Intake
                        Guys, what about electric throttle body? Any ideas? Best around 76mm
                        Audi Coupe Quattro 2.3 20V
                          B5 RS4 / RS3 / TT-RS / RSQ3
                            Alex, maybe 077133062A should be used either, right?
                            • #15
                              Yes but that one is larger - 82mm
