Pedal for E-Throttle conversion?
  • Airwolf
    • Jun 2017
    • 79
    • Country: Norway
    can see that some people in here have converted to e-Throttle on their i5s.
    im going the same way and are looking for a gas pedal that is bolt-on. Can somebody supply me with a part number?
    running Maxxecu Race.
    thanks in advance
  • Rudpavv
    • May 2017
    • 15
    • Country: Poland
    You can use a pedal from a TDI 80 B4
    • Airwolf
      • Jun 2017
      • 79
      • Country: Norway
      this one?
        You need the complete B4 1Z pedal box, and a gas engine throttle pot. Have a check of my project thread mate, all the info is in there
        • s2dk
          • Jul 2016
          • 507
          • Country: Denmark
          Error. Could you plz put a link Up
            • M2ki
              • Aug 2015
              • 547
              No info on that page, you should link the post.
              Users can change posts per page settings, so no point in linking to specific page.
              You need diesel B4 pedal box and TPS from gasoline car. Like B5 and etc.
              1989 Audi 80 Quattro
              • s2dk
                • Jul 2016
                • 507
                • Country: Denmark
                Is there Any tb that has the s2 Stock pattern. For easy swap on inlet ?
                • Airwolf
                  • Jun 2017
                  • 79
                  • Country: Norway
                  Regarding the TPS from d2. Can i use from 4.2 for instans?
                  • grundey
                    • Aug 2005
                    • 125
                    • Country: Latvia
                    D2 - different bolt pattern. A solution would be a flange...
                    Team RS
                    Grundey Intake
                    • grundey
                      • Aug 2005
                      • 125
                      • Country: Latvia
                      For a custom setup I use TPS and pedal from 3.2FSI/2.7biT
                      Team RS
                      Grundey Intake
                      • Tom_
                        • Oct 2007
                        • 1301
                        • Country: Czech Republic
                        Guys, what about electric throttle body? Any ideas? Best around 76mm
                        Audi Coupe Quattro 2.3 20V
                          B5 RS4 / RS3 / TT-RS / RSQ3
                          • Tom_
                            • Oct 2007
                            • 1301
                            Alex, maybe 077133062A should be used either, right?
                              Yes but that one is larger - 82mm
