Replace fuel lines with braided lines?
  • Costash
    • 878
    • Home: Romania Current: United Kingdom
    In the picture 1 is the an6 fitted straight on the hose from tank and 2 is the m14x 1.5 to an6 isn't it? Just to be sure I order the right bits.
    • Jaswan
      • Apr 2011
      • 760
      Looks like number 1 is an m14x1.5 to female -AN
      ​​and number 2 is a M14x1.5 to male AN adaptor.
      Jase.
      • SteveH
        • 4460
        Do you think fitting No1 can be done in situ with the tank in the car? It's a straight pipe from memory so I'm assuming it's a hardline connector, possibly 8mm.
        91 Modded 3B
        14 A6 Avant Black Edition
        • AndyP
          • 6049
          That picture is of my tank, pretty certain that number 1 is this
          https://www.ebay.co.uk/itm/380829671...gAAOxybi9Rc2ku
          Although it's a straight barb, I seem to remember there is a ridge on the end that has to be removed to allow the olive to slide on. Tricky to do with the tank in the car.
          • varia
            • 821
            • Current: United States
            #20
            the problem with these, the hard line inside the tank has very small diameter, like 4.3mm, you can put -an6 fitting on it outside but it will still restrict the flow
            ive removed those small lines inside the tank and replaced with 8AN Stainless Steel.
            • S2_avant 19930325
              • Mar 2019
              • 648
              I did AN8 fittings from the original fuelpump holder on the tank , and AN8 all the way.
              I have a s2 avant.
              • Costash
                • 878
                #22
                Probably the smallest diameter pipe is the return that's why is that small.
                • varia
                  • 821
                  #23
                  supply
                  • Costash
                    • 878
                    #24
                    Thats silly restrictive but for now I am just gonna keep it like it is ... it will do me for 550 ish.
                    • Tom_
                      • Oct 2007
                      • 1301
                      • Country: Czech Republic
                      #25
                      varia On the ends of the pipe inside the tank, is there any fitting or just nothing? Return is clear to me, but feed from pump is just push on the pipe with some clamp?
                      Audi Coupe Quattro 2.3 20V
