Firstly apologies - I'm not great with electrics, please bear with me. I have read a thread on here regarding fans running full time https://www.s2forum.com/forum/techni...nstantly-s2-93 etc - however mine is running when I turn the ignition on, and stays on whilst the car is running. Switch ignition off it stops.
Its a 1993 non AC ABY Avant
I've checked all the fan relays and they seem fine
I've run the test of the after-run system and that fires up on ignition for 5 seconds as it should so assume the 324 relay is good.
I've tried another rad temp sender
Will the 2 blade sender on the water manifold that you cant really get to without taking the rad out cause this? Any ideas appreciated. Or anyone nearby fancy taking a look for me for beers / notes?
