Hi,
The problem I have is that the radiator fan starts to run constantly when I connect the battery. I have tried to disconnect the sensor for coolant temp in the bottom of the radiator. Also have disconnect the two sensors underneath the intake manifold. Without result.
The only way to stop the fan without disconnecting battery is to remove the relay that I have marked on the pictures. The relay is getting constant voltage from somewhere, you can feel that its turns on when mounting it back so the relay is not stuck.
The car have been standing a long time without battery. Worked fine before.
Any ideas or hint on how to proceed are were welcome.
Best regards,
Johan Andersson
Best regards,
Johan Andersson
