When you turn on aircon, it triggers the radiator fan to run as a way to help airflow over the condenser.
In very cold temperatures a thermal switch prevents the aircon from being activated due to risk of damage from pipes freezing on the low pressure / low temp side of the system.
What you describe is normal behaviour... it is good to run the aircon in the winter when you can as it keeps the system lubricated, but the control system is such that it fails safe (off) in very cold weather.
