G4 sensor pin out
  • JuizeR
    • Jan 2010
    • 28
    G4 sensor pin out
    Would anyone know the pin out for G4 sensor?
    Pin 1: +5v
    Pin2: Input to AAN ECU pin 47
    Pin3: Signal ground to AAN ECU pin 48
    Did I get any of them right?
    I don't know about PIN numbers on the actual sensor off top of my head (but can check on a loom here), but the three pins have these functions:
    - G4 reference signal to ECU pin 47
    - signal ground to ECU pin 48
    - third pin is a screen ground wrapped around those other two wires
    • ajax1976
      • Aug 2015
      • 212
      I think it is,
      Pin 1, Ecu ground(48)
      Pin 2, Signal to Ecu(47)
      Pin 3, Chassis ground.
      I could be wrong so hopefully someone more knowledgeable can confirm for you.
        According to schematic for G4
        pin 1 = signal ground (ECU 48)
        pin 2 = signal (ECU 47)
        pin 3 = screen ground (0V)
          snap lol
          • JuizeR
            • Jan 2010
            • 28
            Thanks
              It’s a VR sensor, so you have signal, sensor ground and shield ground as Paul said
              • JuizeR
                • Jan 2010
                • 28
                Yupp, didn't even think of VR-sensors at the time when posting..
                Planning to use G4 pins with 60-2 trigger and maxxecu, as they present on their wiring diagram.
                And as I don't like to cut the harness, I'm just gonna get connector for G4 and reroute 2 wires from that and add a +5v feed to 60-2 trigger as the Lupo trigger is Hall.
                  60-2 on the crank rear seal?
                  • JuizeR
                    • Jan 2010
                    • 28
                    Yes. Am I totally lost on that one as well?
