Catcams 101/1002303
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    Catcams 101/1002303
    hello
    do Any on here run these cams on a turbo engine ?
    If Yes at What power and What turbo ?
    Last how Do you Think they perform in your car
    regards..C
  • momento1
    • Mar 2011
    • 358
    • Country: Australia
    i run these cams
    and they are working pretty good for me!
    665whp on E85 and GTX3582 gen 2
    soon to be GTX3584rs
    Current:
    1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
    Past:
    2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
    2001 Audi S3 Silver - 169kw+ atw
    • s2dk
      • Jul 2016
      • 507
      • Country: Denmark
      Do you run Them at a speciel dec? Or just the one given from catcams ?
      • momento1
        • Mar 2011
        • 358
        Sorry i dont understand? Special dec?
        My cams didnt come with timing marks so my tuner dialed them in old school and set the marks himself.
        Then he left them there and tuned off that.
        They havent been moved relative to their required timing.
        Current:
        Past:
        • s2dk
          • Jul 2016
          • 507
          • Country: Denmark
          You did get What i eas talking about
          i was talking on timing on cams a d you did reply on just What i wanted
          • momento1
            • Mar 2011
            • 358
            ok good. i was thinking that was what you meant.
            cheers
            Current:
            Past:
            • s2dk
              • Jul 2016
              • 507
              • Country: Denmark
              Maybe there is more to get by turning Them and trying different dec when om te dyno ?
              • momento1
                • Mar 2011
                • 358
                Ive been thinking the same thing.
                Unfortunately i havent had the luxury of having the car on the dyno with my tuner playing around with the individual timing of the cams for an extended period.
                Its a long tedious process and probably costly.
                Current:
                Past:
                • s2dk
                  • Jul 2016
                  • 507
                  • Country: Denmark
                  Yah. But Could on the other hand give some serius increase in hp
                  but Maybe we Will know some Day haha. Send me info If you do
                  i Will try these in my engine at some time
                  • momento1
                    • Mar 2011
                    • 358
                    i have a build thread on the forum, but my build is as follows:
                    E85 fuel with EMS standalone
                    currently GTX3582 gen 2 (but eagerly awaiting the install of the 1000hp GTX3584rs)
                    2400cc bosch injectors with twin walbro 450s in tank and with all NUKE fueling gear
                    82mm bore with 9.8cr flat top pistons
                    X-beam FCP rods
                    Stock crank with 10mm girdle
                    FCP springs/retainiers and Supertech valves (all stock sized)
                    Catcam 1002303 profile
                    Minor port work to head (mainly exhaust side)
                    Kavon exhaust manifold
                    3.5in dump pipe, straight through
                    Wagner intercooler and reverse intake
                    Current:
                    Past:
