hello
do Any on here run these cams on a turbo engine ?
If Yes at What power and What turbo ?
Last how Do you Think they perform in your car
regards..C
Do you run Them at a speciel dec? Or just the one given from catcams ?
Sorry i dont understand? Special dec?
My cams didnt come with timing marks so my tuner dialed them in old school and set the marks himself.
Then he left them there and tuned off that.
They havent been moved relative to their required timing.
Current: 1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
Past: 2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw 2001 Audi S3 Silver - 169kw+ atw
Maybe there is more to get by turning Them and trying different dec when om te dyno ?
Ive been thinking the same thing.
Unfortunately i havent had the luxury of having the car on the dyno with my tuner playing around with the individual timing of the cams for an extended period.
Its a long tedious process and probably costly.
Yah. But Could on the other hand give some serius increase in hp
but Maybe we Will know some Day haha. Send me info If you do
i Will try these in my engine at some time
i have a build thread on the forum, but my build is as follows:
E85 fuel with EMS standalone
currently GTX3582 gen 2 (but eagerly awaiting the install of the 1000hp GTX3584rs)
2400cc bosch injectors with twin walbro 450s in tank and with all NUKE fueling gear
82mm bore with 9.8cr flat top pistons
X-beam FCP rods
Stock crank with 10mm girdle
FCP springs/retainiers and Supertech valves (all stock sized)
Catcam 1002303 profile
Minor port work to head (mainly exhaust side)
Kavon exhaust manifold
3.5in dump pipe, straight through
Wagner intercooler and reverse intake
