G25-660 VS GTX3071 VS GTX3571 gen2
  • prj
    • Mar 2010
    • 6308
    Originally posted by A80Avant
    If you can do that then most Greek dyno operators are as you say crap!
    Most dyno operators and dynos are crap, not just greek.
    I've learned this much when working on various dynos.
    • s2dk
      • Jul 2016
      • 507
      • Country: Denmark
      I o ly have this from when i ran a 3076 gen 2 its was at 2 bar boost on a rather Stock aby. 72A68E1C-19ED-4C87-9612-FF47C3F07352.jpeg stock cams Stock cr reverse inlet Big ic
      • A80Avant
        • 10873
        • Country: Greece
        From the look of the graph this must have been a 0.82ar
        • s2dk
          • Jul 2016
          • 507
          • Country: Denmark
          yes it has and only street tuning running a bit to the rich side. but ran well
          • diesel des
            • 3896
            #20
            The new Garrett turbos are definitely interesting. Obviously a 660 won't make 660 bhp, more like 550 at best. I can say I really like the efr 7163 on my stroker with quick spool valve. It dives so nice in high gears. Almost like a diesel. But it keeps pulling after 6k rpm.
            Sent from my Moto G (5) using Tapatalk
            • mushasho!
              • Apr 2007
              • 163
              g25-660 Red vs EFR7163 Blue
              I'm tempted to say that the g Series will be more reliable when overspun, where as EFR's have proven to disintegrate when overspun.
              I can only imagine what the new g28-770 will bring to the table.
              _RubĂ­_
              • Thuppu
                • 4115
                Hmm, when I read the discussion here, it looks like my budget ~500hp turbo solution isn't so bad after all. Seems to be even a tad better than a 3076...
                • running_cold924
                  • Jun 2018
                  • 28
                  Thuppu, what about a GTX 3576 then?
                  • Thuppu
                    • 4115
                    Have no experience with that so can't say a anything, but seems to be quite a lot bigger turbo for higher power levels. Doupt it will spool the same as the smaller competitor..? Could be a fun turbo anyway.
