I recently had a local garage replace my expansion tank (old one was slightly fractured) plus a coolant hose that was severely perished. Since then I don't know if something simply hasn't been plugged back in / knocked but when the engine is running the cooling fan no longer kicks in at 90 degrees (plus a notch or two)
I won't let the car go too far beyond that but as soon as I turn the engine off, the fan kicks in hard and continues to run for a while. The heater still works fine by the way and all coolant pipes that I can locate get hot.
Any ideas / thoughts? I should probably just take it back to them to investigate but thought I'd ask here first, maybe it's a simple fix.
Car is an ABY Avant.
Cheers guys
Cheers guys
