I've been a member for quite some time but I don't post very often. I'm wrapping up a CQ-AAN swap at the moment, and I'm looking for clarity on the radiator fan wiring. I've swapped an ADU harness into my coupe, and I have the 500w fan that I'm integrating. I'm a little confused about the after run fan circuit.
Is it as simple as using the red/white wire from the original coupe fan harness?
The coupe wiring diagram shows the red/white coming from J138, pin 87, but I'm confused as to which way current flows from it (if this is a stupid question, please don't make fun of me too hard).
It just seems odd that if, on the original coupe harness, current flows from pin 87 on that "relay," that it would be a smaller wire on the back side of that resistor than on the other side that goes toward the low speed relay on the next page. Sorry if that description is confusing.
All I really need to know/confirm is, if I'm wiring the 500w fan in my Coupe, and I've swapped in an ADU harness, where does the red/white after-run fan circuit wire come from?
Again, sorry if this is a stupid question. Literally one of the last things I need to button up before being able to get it on the road, along with some vacuum line routing and getting the front end back on the car.
Obviously if that is the correct wire, I'll have to send it to a relay before I connect it to the fan.
Thanks in advance.
Thanks in advance.
