Audi S2 running rich
  • Audi S2 running rich
    A couple of month ago i bought an Audi S2 avant -94. The car had a fire under the hood and some cables was broken. Anyway, everything is fixed now, and the car is runnig, but i have one issue. When I push the throttle to the max the car just cut.. its fine as long as I has the throttle at 3/4
    boost leak.... 100%
    search the forum for boost leak testing...
      I did test it already but didn't found any leaks. Can it have something to do with MAF or the O2 sensor? Or is it like you say 100% a leak?
        Btw - what happens if i connect the charcoal canister wrong? I mean - if i plug in the returnline at the wrong spot?
          Do you have VCDS/VagCom?
          Where in Sweden are you located?
          Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
          http://www.garaget.org/?car=52877
            No, I don't have it. I live in Kramfors, 80km North of Sundsvall
              how did you test for leaks exactly?
                Took of the hose from the turbo, plugged it with a clamp and pressurize it with a compressor .
                  you mean where the MAF fits? in which case i guess you should have found sonething.... it held 1 bar ok for a while?
                    This is a short clip.
                      ahhh.... my apologies, i assumed you meant full throttle while actually driving!!!!
                        Same thing when I drive. But the car is exactly the same when I disconnect the MAF, do maybe that's the problem.
                          Hummm -
                          My S2 was running rich - failed the MOT. After changing numerous items - turned out to be the MAF.
                          Previous readings showed Lam at 1:0 but spiking upwards and running at 1:27 ish.
                          After MAF change now running 0.989 to 1:00 and feels generally all round better to drive.
                          Not saying this is THE answer but it solved mine.
                          The limitation of data on VAG-COM is problematic at times.
                            Originally posted by Bosscat View Post
                            Hummm -
                            I'm pretty sure it's the MAF on my car. Will try to find a new one and see.
                            • #15
                              I just changed the MAF and the car is running worse than before .When I disconnect the car runs fine except I can't floor it without limping. What else can it be?!
