Misfire issue!
  • spencerw83
    • Sep 2018
    • 21
    Misfire issue!
    Hi
    Could anybody help with information about a misfire & severe jerking problem on my 94 ABY coupe? It happens when you get past around 3k rpm when the tutbo starts to kick in, it misfires an the car jerks forwards and backwards. It idles and drives fine at low revs. It’s also an intermittent problem, it’s fine some days and plays up on others. It’s recently had a new crank position sensor and I’ve converted it to 2.0tfsi coils using one of Alex (error404) wiring harness’s, but that hasn’t cured it.
    Any help would be much appreciated!
    Spencer
    Have you pulled the fault codes? Sounds like a boost leak. Do a full pressure test first
    • spencerw83
      • Sep 2018
      • 21
      How do i go about doing a pressure test? Thanks
      • AquaS2
        • 705
        Are the coils new?
        F I R E U P T H E Q U A T T R O
        1996 S2 coupe aqua green sold
        1990 MK2 Golf gti 16v oak green sold
        • spencerw83
          • Sep 2018
          • 21
          Yeah just fitted brand new bosch coils and ngk iridium plugs.
          • Antsa
            • Nov 2016
            • 611
            Here's a guide how to do a boost leak test: https://www.s2forum.com/forum/techni...-testing-draft
            • spencerw83
              • Sep 2018
              • 21
              Thanks mate, appreciate the help!
              • bazburn
                • Feb 2010
                • 583
                MAF...have exactly same on mine, unplug and replug a couple of times sorts it...HTH
                • spencerw83
                  • Sep 2018
                  • 21
                  Really? Well i hope it’s as simple as that! Did that fix it for good or just a while? Is it a problem with the connection or the maf itself?
                  Thanks mate
                  • s2driveruk
                    • 12696
                    Plenty of info under the search button for resolving boost leaks. Check your hoses and jubilee clips and do a pressure check. If the car is new to you then makes a lot of sense to start checking the mile of vacuum lines and intake hoses for cracks and cuts.
                    1992 3b S2 Coupe
                      This ^^^
                      My 3B used to do this all the time, finally fixed by properly cleaning the female pins in the free plug by removing them from the housing and running very fine abrasive paper between the contact surfaces. Then a final clean with De-Oxit contact spray.
                        Read this thread, do a leak test too.
                        That bloomin MAF connector!
                        • spencerw83
                          • Sep 2018
                          • 21
                          Thanks guys!
                          • spencerw83
                            • Sep 2018
                            • 21
                            Well I’ve cleaned up the MAF connectors and it’s been fine the last few days. Hopefully that’s fixed it but it was intermittent before, so only time will tell.
                            Thanks for all the help and info guys! Much appreciated!
                            • bluequattro
                              • 2960
                              Fuel pump.
                              I had same issue with an aby
                              did all things mentioned above with no change.
                              turned out previous owner fitted Chinese copy that couldn't deliver the goods
                              put a second hand v6 one in as I had it and ran fine
