Evening guys (& gals)
Finally took my S2 out today after nearly two months of not driving it!
due to being away and having to replace the radiator. Anyway, thanks to the forum, the radiator change was a successful one
However, whilst I was out the oil warning light came on. I pulled over, checked the level and it's quite high.
Does the oil light come on for the sump being too full as well as too low or is it the oil pressure sender that's gone?
The level is about 2mm above the top fill line so I'm not so worried about it but it is spitting a few specs out the exhaust so bit concerned about the cats.
Is there any simple way of draining a little oil as I've just paid for £40 worth of silkolene to be put in there for my service.
When I changed the oil last year I remember there wasn't a point where the oil was just slowly draining out as I undid the plug. It just poured out.
Anyway, hopefully I'll get this sorted soon as I'm really missing driving it.
Thanks
Dan
due to being away and having to replace the radiator. Anyway, thanks to the forum, the radiator change was a successful oneHowever, whilst I was out the oil warning light came on. I pulled over, checked the level and it's quite high.
Thanks
Dan
