Extra cooling system water pump for ABY engine
  • Extra cooling system water pump for ABY engine
    Can you get this part from any local supplier or dealer....
    I think the part number is
    034965561C
    thanks for any info.
    VW Heritage have it, but its not cheap https://www.vwheritage.com/034965561...-pump-vw-spare
    Its meant to also be fitted in some washing machines from memory.
      Cheers for the information, I will do a little more digging.
        https://rover.ebay.com/rover/0/0/0?m...2F401649641167
          Bosch p/n 0 392 020 034 is a direct fit. The pump is a little shorter and the housing diameter a little less than the oem pump. It only reaches the first rubber holder but stays on just fine. The electrical connector fits straight. I changed the pump few months ago and it wad PnP
            That one on eBay is a lot more reasonable
              I found one with Europarts uk. Just over £70 Inc of the vast.
              removed the pump tonight can't find any leaks from the pump and all the clips were tight...typical with slight leaks..
                If this is the after run pump isn't it the same as VW transporters which are alot cheaper but the same pump?
                  A TT water pump and change polarity to the plug.
                  Easy
                  photobucket SUCKS
