Extra cooling system water pump for ABY engine
  • quattro estate
    • Aug 2015
    • 188
    Can you get this part from any local supplier or dealer....
    I think the part number is
    034965561C
    thanks for any info.
    VW Heritage have it, but its not cheap https://www.vwheritage.com/034965561...-pump-vw-spare
    Its meant to also be fitted in some washing machines from memory.
    • quattro estate
      • Aug 2015
      • 188
      Cheers for the information, I will do a little more digging.
      • LHD_Kid
        • May 2006
        • 3696
        • Antsa
          • Nov 2016
          • 611
          Bosch p/n 0 392 020 034 is a direct fit. The pump is a little shorter and the housing diameter a little less than the oem pump. It only reaches the first rubber holder but stays on just fine. The electrical connector fits straight. I changed the pump few months ago and it wad PnP
            That one on eBay is a lot more reasonable
            • quattro estate
              • Aug 2015
              • 188
              I found one with Europarts uk. Just over £70 Inc of the vast.
              removed the pump tonight can't find any leaks from the pump and all the clips were tight...typical with slight leaks..
              • Rikki Kitto
                • Feb 2010
                • 6276
                If this is the after run pump isn't it the same as VW transporters which are alot cheaper but the same pump?
                • M_GORDON
                  • Oct 2008
                  • 1295
                  • Home: Isle of Man Current: Vatican City State
                  A TT water pump and change polarity to the plug.
                  Easy
                  photobucket SUCKS
