Wagner Evo2 Gen.2 intercooler intstal question
  • Dobby84
    • Feb 2011
    • 1169
    Hi,
    At the weekend I started to fit my Wagner intercooler along with the BST inlet manifold and have a question regarding the fitment of the boost hose from turbo to the intercooler.
    The current hoes is not long enough and is also at a different angle so will not line up with the adaptor that came with the intercooler.
    Has anyone else come across this before or has a solution? Turbo is in the original location.
  • Colesy
    • Feb 2009
    • 2980
    You have to chop the old hose, then use a piece of metal tube to join the old hose to a reducer that mounts onto the IC
    • Dobby84
      • Feb 2011
      • 1169
      Okay thanks, was thinking I would need to do something like that but wasn't sure about the angles.
      • M_GORDON
        • Oct 2008
        • 1295
        • Home: Isle of Man Current: Vatican City State
        It's a shame...
        so expensive and you must cut your hose and search and buy a metal ring
        Lamentable
        photobucket SUCKS
        • Dobby84
          • Feb 2011
          • 1169
          Yeah I know. Nothing aftermarket seems to be an easy fit
          • sjw185
            • 1175
            I used a 45deg silicone and a alu 90 with reducer at turbo.
            Think the pipe and hose were 70mm
            This gallery has 1 photos.
            • rxl
              • 1913
              what efr turbo is hiding there?
              • sjw185
                • 1175
                • Dobby84
                  • Feb 2011
                  • 1169
                  Looks like an easy enough solution but where is the DV located?
                  • sjw185
                    • 1175
                    Oh yea never though about that as mine is on the turbo.
                    Suppose you could fab a metal tee or use a silicone branch but starts getting expensive.
                    Whats your plan for the throttle side?
                    • Dobby84
                      • Feb 2011
                      • 1169
                      Maybe I could use the old silicone pipe which attaches to the throttle with the tee for the ISV
                      I have the silicone pipe from the intercooler kit and a reverse BST manifold that I am currently trying to fit.
