Hello all.
At my last MOT the tester commented on an oil leak coming from the front of the engine and said "its probably not bad enough to fail this year but you ought to look at it".
It is hard to say where the leak is coming from without doing some disassembly so I figured to take it all apart and have a look, I have new seal and gasket ready. Knowing the gasket between pump and block cannot be changed without dropping the sump, I'm sort of hoping it is the crank seal...
I see different sorts of oil seal removal tools are available and all of them seem to work so I was just wondering if anyone had any first hand experience of how they got on with the job with pump in situ. If it is the gasket then the pump comes off anyway and I can push the seal out from behind but just in case I get lucky; I'm hoping to do the job with minimal disruption.
types of tool I've seen.
Pick type pullers that hook in behind seal and pull.
Screw in type pullers which i think thread into the edge of the metal outer housing then you pull
or the ghetto way of drilling holes and screwing self tappers into the metal body of seal then pull tool. Not sure i fancy this because of the potential for disaster but it is pretty cheap (assuming nothing goes wrong!)
A twin hook bearing puller type tool which gets in behind the seal lip and a centre bolts acts against end of crank to draw seal out.
Thanks all.
Thanks all.
