Did a RS2 boost leak test yesterday and pretty much it bled all the air directly trough the wastegate, and quite fast. Blocking the hose to the lower chamber revealed the system is airtight with no leaks. The car does reach its boost level but it isnt the quickest spooling RS2 I've driven... is this amount of play on the WG-valve a massive amount or is it still a normal bit of wear? Never checked this before but I'd say the valve guide has almost vanished?
https://youtu.be/mSanFbeOwjM
Thanks!
Steve
Thanks!
Steve
