Audi S2/RS2 not starting
  • s0_big
    • Dec 2009
    • 685
    Originally posted by Mikes2
    http://s2-audi.co.uk/workshop/schema..._aby/page5.png - pin 37 is switched 12v at the ecu for the injectors
    Ok, then I have checked that. I have 12V with ignition on and also while cranking at the injectors.
    • mllen89
      • Apr 2015
      • 63
      measure if you have 12v between pin 4/6, 5/6 in the maf connector ? with it still mounted, have you tried to start it wiith the maf unpluged ?
      • s0_big
        • Dec 2009
        • 685
        Ok, Will check that. I have 12V to the maf that i have measured. I have tried but no start.
        • GT500
          • Jun 2006
          • 2181
          Even though you have fuel at the rail and it is flowing through if they are on the wrong way around you won’t get the right pressure. Get a gauge on it. Pressure has to be right. You can use a tyre gauge if you have to.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • andersg
            • Feb 2015
            • 100
            • Country: Norway
            #20
            You can easily bypass the alarm (inside the central locking box) if you make a jumper cable between switched and permanent 12v into the ECU. It caused me a lot of headache.
            • twoqu
              • Sep 2003
              • 3103
              #21
              Another known issue is the actual injector connectors themselves. Would be a bit unlucky to have all five not making contact but worthwhile eliminating them.
              They crumble inside so it might not be obvious.
              • s0_big
                • Dec 2009
                • 685
                If it is an alarm issue, what's the symptoms then?
                • Vauhtiveikko
                  • Jun 2010
                  • 250
                  Make sure that also this plug is as it should...
                  S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
                  • s0_big
                    • Dec 2009
                    • 685
                    I have measured both 12v+ and minus- on all connectors. I will continue tomorrow with the fault finding.
                    one thing that popped up my head is that I removed the hood, there was 2 cables that I had to cut to get it off. Could those two cables make these kinds of problems you think? Maybe some earth point thats interrupted? First thing tomorrow I will bolt the hood back on and these two cables to make sure thats not my fault.. Thanks for all the help and replies so far
                      • Dec 2017
                      • 5984
                      I think the wires you cut are to the heated washer jets or the under bonnet light. Shouldn't make any difference but make sure its not shorting out.
                        • Dec 2017
                        • 5984
                        I had non starting issues. Took me weeks to find what the problem was, slowly eliminating one possible cause after another. You may have already read in my thread but it was found to be the top cambelt pulley key which had sheared, allowing the timing to slip enough for the engine not to start. I still had spark, fuel, compression, just at the wrong time! The key sheared because during the engine re build it wasn't torqued up correctly! The only way to see it was to remove the rocker cover as the timing marks slipped to a position where they lined up again.
                        • twoqu
                          • Sep 2003
                          • 3103
                          #27
                          Didn't get a answer to your earth/ground readings. On pin 30 you have said its 18M Ohms? Was that a mistake?
                          • s0_big
                            • Dec 2009
                            • 685
                            No thats correct. But I have ground at the sensors that are connected to pin 30 when I put the ECU-connector to the motronic. Read some were that the ground to pin 30/48 is taken from either 10/14/19/24 through the ECU and out to pin 30/48. Correct me if I'm wrong. Then thats maybe my problem.
                            • s0_big
                              • Dec 2009
                              • 685
                              Yeah, i have read your thread
                              • twoqu
                                • Sep 2003
                                • 3103
                                #30
                                But I thought you said the readings were with the ecu connector off. So shouldn't that be directly to ground and 0 ohms?
                                Can't remember if pin 30 is the main ecu earth if you see what I mean. The one that is attached to the A pillar rather than the ones on engine.
                                Will have a think about it.
