Hello all
Lately my S2 has been suffering from occasional smoking. It annoying because I have not found anything that would clearly point me the reason. Here is what happens:
- never smokes when started cold
- seems like smoking happens when engine is under vacuum (lightly cruising)
- no smoking under boost
I did change the oil from 10w50 to 10w40 in the spring but it has been fine until now. Could the less viscous oil be the cause? I know that worn rings, bad valve stem seals, crankcase ventilation system and leaky turbo seals can cause smoking problems. What would be the best way to proceed and how to verify/rule out the possible causes of the smoking?
Thanks in advance
Antti
Thanks in advance
Antti
