ABY Cruise control fault
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    My cruse control has stopped working.
    I feel daft asking this but can somebody advise were is the control module situated.
  • Nuvo
    • Nov 2003
    • 3825
    It's mounted on a bracket in the area behind the dashboard carbon/wooden trim insert above the glovebox. Open the glove box and insert your hand up in this space and you'll be able to touch it.
      I would first check the vacuum diaphragm & pedal switches. These are the common failure points.
      • M2ki
        • Aug 2015
        • 547
        Dry solder joints on the cruise module PCB is very common. Brake bulbs must also be working for cruise to activate.
        1989 Audi 80 Quattro
        • orsum
          • May 2010
          • 1213
          Going to start with the easy stuff first.
          Brake bulbs working. Warning light for a defective bulb comes on when starting the car.
          One press of the brake peddle and the warning clears. I guess this is the normal operation. Is that correct?
          • Michael S2
            • Dec 2011
            • 1378
            Yes that's normal
            1995 Audi S2 Avant
