RS2 engine misfire
  • RS2 engine misfire
    The engine was misfiring I found out No1 spark plug was black and not firing after changing the plug it worked fine but after a while the misfire started again can anyone help me on this topic?
    Ignition amplifier good?
    Nothelle S2 Avant in restoration
    Wr Ur Quattro (also in restoration)
      Sorry about my inexperience on this issue what is the ignition amplifier and where is it situated?
        Two black boxes on the bulkhead. Follow the ht wires back.
        better still, convert to coil packs. Error404 here does a really good kit!
          I have already installed 404 coil pack
            Ah. So could be a faulty coil pack. Did you get new ones?
            try swapping one over?
              Yes I bought a set of new coil packs from error 404 which are now installed
                Ok, should be good then. Check its seated properly on the plug. Mine need pushing down now and again as I don't have a cover. Failing that, over to the experts. They will be lurking
                  Hi dave I just sent Alex a message to that affect maybe he might have a solution but thanks for your advice on this matter. I still cannot download photos of the finished paintwork on the car its ashame I am sure you would like to see them.
                    Yes, looking forward to that.
                    I don't think it will be anything to do with the harness. When I had my engine problems, my fully qualified VAG mechanic had Error's harness to bits and said it was the best made he had ever seen and could find no fault whatsoever. As long as its properly connected it will be fine.
                    Misfire on one cylinder can also be caused by dirty or blocked injector. Did you have them cleaned and flow tested? Lynn (LSG) can help there. Only other possible cause could be low compression on that cylinder. Try swapping the coil packs over just in case as well.
                      I had the injectors restored and tested and compression test is correct
                        And finally, good petrol?
                        You seem to have covered everything and exhausted my limited knowledge. Like I said, a proper expert will be lurking and probably have a good idea what's wrong. If you swapped a spark plug over and it was good for a while, then went bad again, that needs investigating. Find out why that happened and you will have hopefully solved the problem.
                          Admittedly it has unleaded in the tank I was advised to put V Power fuel again thanks for the advice Dave
                            How long did you leave the injectors between having them cleaned and using them? I've read that cleaned injectors can have issues if not used for a while after cleaning.
                            91 Modded 3B
                            14 A6 Avant Black Edition
                            • #15
                              good point I have started the engine occasionally after installing them but they have not had a long run in period as the car is being restored
