Spark plug condition
  • Rikki Kitto
    • Feb 2010
    • 6276
    Asked the same question on the facebook page but felt I might get more sensible answers on the real S2 Forum page what do the state of my plugs say? They have been in about 1 year the car hasn't been at the bottom of a lake and I regularly spend loads on the car
    This gallery has 4 photos.
  • tango123
    • May 2017
    • 892
    shouldnt look like that after 5years let alone a year. water ingress some how
    • SteveH
      • 4460
      Never seen plugs like that on an S2 due to their location deep in the head. Do you live by the sea??
      91 Modded 3B
      14 A6 Avant Black Edition
      • Rikki Kitto
        • Feb 2010
        • 6276
        I use the new coils with the conversion loom and now have no sealed coil pack cover, what about the oily one
        • Thuppu
          • 4115
          Propably your valve cover seal is leaking at that one. Never seens so corroded plugs before
          • Colesy
            • Feb 2009
            • 2980
            The coils should seal depending how much of the rubber you cut off them. The oily one is probably due to a weeping cam cover gasket.
            • Bowie69
              • Nov 2013
              • 2675
              Only tend to see this on engine bays that have been washed off with a hose/pressure washer.
              Oily one will be because of the rocker gasket, or maybe if you are unlucky, a loose plug and poor oil control rings.
                • Dec 2017
                • 5986
                They look like they came off a car that hasn't seen new plugs for 10 years! Did someone swap them when you weren't looking?
                • steve briance
                  • Aug 2014
                  • 1455
                  has your car been worked on by anyone else? Those plugs looks rough. Re the oily one, at least on the bright side the oil is on 'the outside' and not on the tip where you might consider ring or valve guide wear
                  • Fat Audi 80
                    • 10547
                    They look like they have never been changed!
                    The Perfectionist
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Cheers peeps will have to keep an eye on why water is getting down the plug recesses, maybe the coil tops aren't sealing properly
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        Our engines don't like water so if you do ever wash the engine bay, important to cover up certain items like the top cover, alternator, belts, fuse box area etc just to be safe.
                        1996 S2 ABY Silver
