Is the fpr 4 bar on the aby ? And any one got a part number
Vcds code 00561 mixture adaption exceeded
Originally posted by bilko0795 View PostIs the fpr 4 bar on the aby ? And any one got a part number
Copies about a tenner, genuine bosche ones about 40-50 quid.
Did you do a leak test?
Originally posted by bilko0795 View PostJust wondering if the fuel pump is playing up it is 25yr old and it’s the only thing iv not changed since iv had the car
Ive had the same code since doing a top end rebuild and turbo swap. Ive swapped almost everything from MAF to FPR and everythjng in between lol. Only thing ive not swapped out is the pump. Car runs fine and there are no big issues. Fuel pressure is higher then what it shoild be...im sitting between 56-58psi at idle. Could be a bad return line causing a spike in fuel pressure, hell could still be a boost leak somewhere. The car is not a daily so its parked for winter. Ill attack this in the furure at some point.
pretty much going to live with it for now. I have plans to build the engine more or replace with a built engine in the future.
im interested to see what come of this thread though.
Been using the car now all week no issues until this morning. I left the house car cut out after a few hundred meters wouldn’t start went to work got a tow rope and some help got to the car it started first turn short lived though traveled a few mtrs cut out started again few mtrs cut out again left it a few minutes started again and got back to the house I haven’t plugged it in vag com yet but I was thinking either fuel or maf related?
