what size hose for coolant adaptor
  • what size hose for coolant adaptor
    Anyone know what size of hose goes on the coolant adaptor on the block on a 3b/aby?
    Its the water feed to the turbo if im not mistaken. Its under the exhaust manifold.
    cheers
    I can measure this later today for you. The hose is teflon lined by the look of it.
    91 Modded 3B
    14 A6 Avant Black Edition
      Tanweer, I will make you a core plug with a -6AN fitting on it
        Thanks for the reply steve.
        Alex that would be great. How does the old adapter come out?
          You can pry them out, but watch you don't damage the opening for the core plug in the block. Search 'core plug removal' on Youtube.
          91 Modded 3B
